Old 02-07-2017, 01:19 PM   #9
r00ster
I'm now starting to lean towards either the wheel bearings or the outer CV joint. I put the rear end up in the air and put the car in drive and listened with a mechanic's stethoscope. Nothing out of the ordinary when I touched the diff cover but I could faintly hear the squeal when I touched the bearing carrier. Typically, CV's don't squeal (and I recently repacked them) and usually, bearings don't neither but if one of those two is going to squeal, it's most likely the bearing, right?
r00ster is offline   Reply With Quote
