Hello all. I'm the second owner of a gorgeous mint 2001 Porsche Boxster S. The coolant flush, rear main seal and IMS retro kit were all installed by Redstone Performance Engineering in Lebanon, IN. This shop works on half million dollar Ferraris and Porsches and is currently restoring several Indy Cars. The car is as mint as a 986 can possibly get and even has the original paperwork from the previous owner who ordered the Boxster S with the following options:
Sport Touring Package (Option P64) as well as the 18" allow "turbo look" wheels (Option 413).
Other options include Porsche Stability Management (476), Self-Dim mirrors and rain sensor (P11) Savanna Beige Floor mats (M6S) and Special Chassis Rigidity Tuned (030).
The tires have plenty of tread with less than 5k miles on them and exhibit no signs of cracking or any other deficiency. The car has been inspected and anything with even the slightest hint of necessary TLC has been replaced.
Many pictures were taken during inspection and replacement of parts and are available upon request.
In the last 2 weeks the following has been done:
Cabin Air Filter: Inspected and replaced with charcoal embedded Mann filter
Engine: Inspected and replaced Mahle air filter. Hoses and belts inspected for cracks. Oil and oil filter replaced with Hengst filter and Mobil 1 0w40 Synthetic. New drain plug washer installed. Slight oil seapage between transmission and engine. Rear main seal was replaced during IMS retro kit install. Oil filter inspected for debris with none present.
Throttle body: Removed and inspected. Slight residue buildup on butterfly. Throttle body and plenum cleaned inside and out. Computer calibration completed.
Oil/air separator: No abnormal oil residue in throttle body or plenum.
Spark Plugs: Replaced with Bosch 7413 plugs.
Coil pack check: Inspected for cracks.
Engine bay check: Cleaned with damp rag and inspected.
Battery check: Battery was load tested. New battery installed.
Brake system check: Hydraulic fluid flushed. Pads and rotor thickness inspected. Caliper piston seals inspected. Master cylinder tested. Brake booster tested.
Cooling system: pH tested. System checked for leaks or cracks in hoses/radiator. Coolant system flushed with G40 coolant.
Tire and wheel check: Tires show no cracking or dry rotting. Front wear aprox 75-80% remaining. Rear wear aprox 70% remaining.
Clutch condition: Engagement / slippage checked. Friction disk and flywheel inspected during IMS/RMS install.
Transmission check: All gears were smooth and precise. Drive shaft boots inspected for cracks.
Convertable top conditoin: Cloth cleaned and inspected. Rear window plastic cleaned and inspected.
Rear spoiler: Functions normally.
Exhaust: Inspected for abnormalities. Very slight rattle near converter hanger when idling but not audible inside vehicle.
Body: Front bumper shows very minor wear acceptable for age/miles. Bumper was removed and painted then installed back on vehicle. Body inspected for dents/scratches with no obvious issues. Paint washed and waxed.
Glass: No obvious marks,cracks or scratches.
Interior: Audio system checked. Auto dimming mirror repair and was then installed back in vehicle. Windows checked. Locks checked. Horn checked. Cruise checked. Carpet shows no obvious wear or marks. Door panels/dash shows no obvious wear or marks. Leather seats show no cracks or obvious wear. Dash guages and lights tested. Convertable power top operation checked. All electronics and buttons function. Leather cleaned and conditioned.
Suspension: All struts checked and bump tested. Bushings checked. Alignment checked.
Steering: Steering feels smooth and returns to center. Hydraulic system checked.
Misc: Original user manual, window sticker, and purchase order present. Battery storage charger present. Both original keys with valet key present.
Drive test: Throttle feels smooth with no hesitation and is strong throughout RPM band with most power felt in upper RPM band as predicted. No audible suspension noises or abnormalities over bumps. Handling feels firm during corners with a smooth but quick weight transfer as expected. Alignment satisfactory with no abnormal tendencies. Brake application has good bite and does not pull left or right. Interior road noise level normal. Audio system is normal. Convertable top operates as normal.
Below are the most recent pictures of the Boxster S. If you have any questions please don't hesitate to ask. You can easily reach me on my cell at 317 496 4893, Dan.
20170207_133831[1] by
dsmithwc04, on Flickr[/IMG]
20170207_133926[1] by
20170207_133852[1] by
20170207_133940[1] by
20170207_134047[1] by
20170207_134117[1] by
20170207_134151[1] by
20170207_134206[1] by
20170207_134306[1] by
20170207_134324[1] by
