Thread: Creaking strut
Old 02-03-2017, 08:12 AM   #20
ttomtom
The drop links come out really easy if you take the loading off them. Just use a jack to raise the LCA at the ball joint until the load is released. They will slide right out. I removed the lower bolt first and it made it easier to remove the upper one
I also removed the lower bolt. There's no load once the top of the strut and the other end of the drop link is unbolted. The wheel carrier is just held by the LCA. I even removed the fork arm.
ttomtom is offline   Reply With Quote
