Old 02-02-2017, 05:29 AM   #1
porsches2944
FS: Competitive Spec Boxster
New build for the 2016 season. Three race weekends, current logbook, no crashes.
Build as follows:
LN engineering bearing, accusump, remote oil filter, aasco flywheel, underdrive pulley, Wevo engine mount, all emission systems removed, and capped, 3.2 oil cooler, new plugs, oil separator, all filters, custom exhaust, new air mass sensor.
Factory hardtop, gutted with Lexan rear window, full custom cage with NASCAR bars, cage is attached to a-pillars, window net, OMP HTE-R 400 composite seat, OMP 6 point HANS compatible harness, Sparco R-333 steering wheel with Momo quick release, steering wheel hook, shifter riser, cool shirt system, wide angle rearview mirror HVAC removed and holes plugged, doors and dash gutted, lightweight battery and kill switch, fire extinguisher, fixed rear spoiler, rear bumper cut out, front and rear tow straps, Rennline tie downs.
Front and rear GT3 lower control arms, front and rear GT3 adjustable sway bars, GT3 front brake ducts, Tarett drop links, Torque solutions rear toe links, PSS9s with swift springs, stainless steel brake lines, wheel bearings, rotors and Pagid pads, wheel bolts converted to studs, square wheel set up.
Ready to race, just add a transponder and a driver. More pics available on request.
Feel free to email with any questions- porsches2944@yahoo.com
35K OBO
porsches2944 is offline   Reply With Quote
