Old 02-01-2017, 01:12 PM   #3128
dsallean
Finished installing both variocam tensioners with new pads, 3 new chain tensioners, new rear main seal, new daul mass flywheel, clutch and pressure plate. Also replace AOS while it is a little easier to get to with the transmission out. New plugs, new plug tubes and o-rings. I am probably missing a few things as well...
Still need to put the transmission back in and install new front engine mount. And need to install new cat delete pipes.
Oh, and I removed and replaced the IMS.
Dave
2001S
dsallean is offline   Reply With Quote
