Old 01-31-2017, 06:56 PM   #2
zealous
BTW a bad battery can cause a lot of issue!
After putting in the new battery fix everything and runs strong now.
I had a ton of errors coming back and my check engine light on.
Some of the codes were Secondary Air Pump
The car would get stuck in 4th gear and sometime the D would blink and not even show my current gear that I was in.... all of this was caused by my bad battery.
I ended up buying the EverStart Maxx Lead Acid Automotive Battery, Group Size H7
I have to drive 12 hours so will let you know if there are any issues.
I had read somewhere (I think Pelican Parts) Everstart work very well and they are rated one of the best battery's, it fits and has a outlet valve on both side so it was easy to install, just drop and connect.
zealous is offline   Reply With Quote
