That is a strange noise. When you tested the bearing - how old are you current ones and have they ever been replaced? I've had bearings cause some seriously strange noises and symptoms before. Sometimes noises/symptoms that didn't make me think it was a bearing. Curious, when you are traveling at the speed in the video and the noise is emitting, did you try to turn and put load on the left or right wheel to see if the noise changes or stopped?
