Thread: Winterizing
Old 01-30-2017, 08:38 AM   #15
Ciao
Ciao's Avatar
Originally Posted by Need_for_speed View Post
Many of us up here in New England do what I call "soft" storage. With the mild winter, I've been able to take the car out once or twice a week when the streets are dry. I keep the gas tank full and add a dose of Stabil 360 since I won't be changing over fuel as much. If we get snow and it looks like it might be a few days before the streets are clean enough to take her out, I'll plug in the CTEK. My garage is well insulated and stays pretty warm, but if we have a serious cold spell, I'll slide in some wheel chocks and release the e-brake. I'll also release the top with the handle to relieve the tension on the top mechanism.
One other note: I swap over to winter tires as well. I don't like to drive summer rubber when the temps are less than 50 degrees.
Releasing tension to top mechanism of convertible top sounds like an idea ill add to my list
5280 Cruising @High Altitude
Seal Gray & K&N Filter
