Old 01-30-2017, 08:21 AM   #29
mikefocke
OTOH, it depends a lot on where and how you drive if the 6 speed is preferable to the 5-speed. Some prefer the 5 speed gear ratios.
Less power can be more fun as you can put that accelerator foot down harder longer without attracting expensive enforcement attention. I'd rate my 85HP 914 more fun in that regard than my 201HP base or my 250HP S.
Certainly the impact on the rear axle CV joint boots is worse in the 6 speed cars so have the PPI check the boots carefully.
