Old 01-29-2017, 05:57 PM   #1
offroadjim
1998 Boxter Windows will not work
Hi
I have acquired a 1998 Boxter and was having problems with the ignition switch. I replaced the ignition switch and that problem is solved but now the windows will not go up or down using the switch. They do lower when I open the doors and then raise when I close the doors. I can not remember if the interior lights worked when I got the car but they are not working currently. I do not have any type of experience or manual on this car so I do not know if they use the same fuse in the panel on the floor but I used a test light and they all seem to have power on both sides of the fuse.
Any ideas what fuse it is or where to look first?
Jim
offroadjim is offline   Reply With Quote
