Add a fuel stabilizer to your gas tank and fill it completely.
Change the oil.
Do not start the car up unless you are going to drive it and warm it up to normal operating temperature.
Use a battery tender to keep the battery fully charged.
Do not close the frunk completely because otherwise you won't be able to open it if the battery goes bad.
Read up on how to unlock the car without setting off the alarm after it has been sitting for about five days. I don't lock mine since it is in a garage.
Prevent mice from setting up house with moth balls in the cabin, trunk and frunk, and put traps or poison at all four corners of the car.
Roll the car a bit back or forth every few weeks to avoid developing flat spots.
1941 Dodge Luxury Liner Coupe
