Thread: Clutch effort
Old 01-24-2017, 04:07 PM   #5
JayG
On the slippery slope
JayG's Avatar
Since it is a hydraulic clutch, you can't really tell when its worn until it starts slipping. The pedal pressure should be the same new or old
If the pedal feels hard to press, most likely its a broken clutch booster spring. A fairly common failure.
You can replace the spring with one from McMaster (?) or find a used one (Woody) or buy a new one for around $60
do a web search and you will find a couple of threads on it
2004 996 Targa Tip
Instructor - San Diego region
