On my other car I sprayed and cleaned about a inch or two from above the pan gasket everything below with brake cleaner or carb cleaner wipe or air dry then immediately start the car and look for leaks. This could eliminate the pan gasket altogether. These solvents dry real quick being alcohol based.
