Old 01-20-2017, 05:15 PM   #14
moosport
I had to order longer bolts than the using the lug bolts, I got them at MR. Metric
This is what you will need
M41086 - M14X1.5X60 Hex Bolt Cap Screw Steel 8.8 DIN961 Fully Thread
A word of caution, once you have three bolts making contact with the bearing seperator , go only a turn at a time or less in a crosswise patters or you will bend the bolt...I know. Once you do this the hub came off pretty easy....and yes the bearing came apart when I did this. When you pull the actual bearing it iwll take a pilot a little smaller than you think....keep the puller greased very well with a high quality lubricant (Do not even think of using WD40 it is not a lubricant) and that bearing will come right out.
Placing an order for it right now. I was wondering why the hub has not budge but I'm out of thread.
moosport is offline   Reply With Quote
