Old 01-20-2017, 09:40 AM   #17
WorkInProgressK
Thanks for chiming in JFP.
The leaking 'O' rings were supplied by Parts Container as part of a kit. The replacements are from Pelican .When I removed the heat exchanger the bolts were tight and the seals looked perfect. Dimensionally they are suspect and they 'feel' different(durometer?) from the new Pelican parts. The engine has zero miles - just test run.
After I position the new Pelican 'O' rings on the engine ,I'll use a straight edge and feeler gauges to measure how proud they are of the mating face of the crankcase. Odd that the stock spec calls for 4mm thick coolant rings but thinner 3mm oil rings. I suspect the measuring is irrelevant. Durometer is probably the issue which is difficult to test empirically diy. And then there is the material choice-HNBR,Viton.Buna(I hope not!). Hence buying from Pelican and trusting them.I presume it is verboten to use any sealer?
Here are the part numbers for the convenience of others.
999-707-389-40
999-707-409-40
The issue with sealer on the oil side is contamination post oil filter and pre oil passages. As the silicone doesn't really degrade in oil and block passages.
What you could use is grease made to swell rings. Done right you shouldn't need any sealant. One other issue with sealant is that it takes a good .010" to .020" of space when done right, which would be bad for the O-ring interface.
HNBR is probably your best choice.(green rings sometimes black). Black rings are probably NBR which aren't bad, just not as good as HNBR.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
