Old 01-19-2017, 09:20 AM   #27
JFP in PA
Originally Posted by fishski View Post
Thanks barkinfool...I assume the plate removal is straight forward? I have read were taking it off can result in alignment problems but I think the alignment problems come if you take the support bars off which I have no plans on doing.
As the support bars are underneath the pan, I'd like to see how you are going to do that:
Removing the pan does not cause alignment issues, but putting it back often does require "encouraging" the uprights into position with a small ratcheting tie down strap.
