					Originally Posted by  moosport
				My wheel bearing replacement job is on hold until I figure out how to remove the hub. I bought the large bearing separator from Harbor Freight. But the hub still will not budged.
The axle nut is easy. Using the handle of my floor jack makes removing the nut a short order.
I had to order longer bolts than the using the lug bolts, I got them at MR. Metric
This is what you will need
http://www.mrmetric.com/M41086
A word of caution, once you have three bolts making contact with the bearing seperator , go only a turn at a time or less in a crosswise patters or you will bend the bolt...I know. Once you do this the hub came off pretty easy....and yes the bearing came apart when I did this. When you pull the actual bearing it iwll take a pilot a little smaller than you think....keep the puller greased very well with a high quality lubricant (Do not even think of using WD40 it is not a lubricant) and that bearing will come right out.
