Thread
Heat Exchanger delete+oil cooler added
01-18-2017, 05:24 PM
11
specboxCO
If the coolant system is working as it should, it has way more capacity to remove heat from the oil than is needed. If you have an overheating issue, it is almost 100% on the water side. There is no need at all for an external oil cooler.
specboxCO
Find More Posts by specboxCO
