Old 01-18-2017, 09:01 AM   #11
Smallblock454
Originally Posted by jakeru View Post
UPDATE: my chatter problem has magically
Now the clutch system still isn't perfect, as my wife still complains the clutch pedal being heavier than she'd prefer; every once in a while after an extremely cold start without the clutch pedal being pressed in, the throw out bearing will make some awful noises; and practically all the time, the clutch system makes some groaning noise/vibrations when the pedal is moves (which seem to be originating back/underneath at the transmission). So, I imagine eventually I'll still do some work back in the clutch area (and have pretty much all new replacement parts already lined up). But at least the chattering is no more - it's totally smooth engagement, all the time!
I suspect the damage is now worse than before. A clutch system doesn't heal itself.
You'll see when you disassemble. I wouldn't wait too long.
Regards, Markus
