Replacing the hub carrier
If you are replacing the hub carrier there is no need to try and pull the old one in place. Break down the carrier and remove, take it to a machine shop or if you have a hydraulic press install a new wheel bearing and hub....reassemble and have it aligned. Usually pulling the hub will pull the race off the wheel bearing, and while you have it out and apart you might well nip this in the bud for later.
Dwight
