Old 01-17-2017, 04:23 PM   #3
Steve Tinker
Steve Tinker's Avatar
You may have an air pocket in the cooling system - be very careful not to overheat the engine with this loss of coolant..... How does your oil level look - any indication of water in coolant (milk shake), indicating an internal coolant leak.
1) Try cleaning the inside of the tank using a rag dipped in vinegar - try a screwdriver if your fingers are short - just enough so you can see the level
2)Top the coolant up with distilled water.
3) Under the black plastic cover in your photo, you will find an expansion valve with s chrome D shaped ring - lift the ring up into the vertical position (that's open) and drive your car for 3 - 4 days to expel any trapped air. Check the coolant level daily until it stabilises.
4) Return D ring to its close position.
5) If the level still goes down, you have a leak - return it to your mechanic pronto.
2001 MV Agusta F4.
