Well... I dont know if this will help you but to remove the carpet in the foot well pull away from the center of the car just enough to pop the tabs then pull towards the front of the car. Then to remove the trim pieces beside the trays in the center you just do the same thing. Pulling out the drawers is easy, you have to do the top one first (assuming you dont have cup holders or a cd changer). That leaves everything in the middle pretty much open, so hopefully you can route it up the dash easier, this is a fairly good car for taking apart so just take your time.
