2.6 - 3a is way high. Your battery probably has 120aH of capacity so in about 40hrs, you'll have a dead battery
Start unplugging stuff... I would start with the easy stuff - disconnect cd changer, check current draw, then move on to the amp (assuming you have the factory amp)
