Old 01-16-2017, 09:29 AM   #1405
particlewave
Charles, the relay you linked to has 5 pins on it, I assume it will be easy to figure it out once they arrive? How are you connecting the wires to the relay? Soldering or a spade connector? Thanks for your help.
I solder the wires on. The relay has 2 pins on one side and 3 on the other. The 2 pins are the coil and are connected to the low beam (red and black, polarity doesn't matter). The 3 pins are the contacts. I'll have to look to see which is which and report back, but you could easily determine that with a multimeter or even a test light.
