Old 01-15-2017, 11:19 AM   #1399
particlewave
If you want it to work correctly and pass inspection, you will also need a relay to switch between halogen and HID high beams as you cannot flash HIDs from an off state (daytime high beam flashing).
My point was/is that this kit that Fred offers is just that: a kit. It requires professional installation to ensure everything is done correctly and meets minimum local law requirements. Order some standard relays for the high beam functionality and some of the smaller relays that I posted above for the AEs so that this doesn't happen again.
