Gelbster, I could try that using 1-1/4" adaptor, but the OEM TRW's flat inner end is octagonal and measured diameter of exactly 31.75mm(1-1/4"), so I think metric adaptor of 32mm will be fit which is absent in that sort of set. Furthermore,I have to reinstall the inner tie rods of Miata NB1 and 2011 Mercedes GLK 220, 4Matic blueEfficiency. So I would go to the universal function.
When I torqued 50 ft-lb against to steering rack in my 2002 Miata NB with the Saginaw type steering rack set using different type of adaptors( suitable for Miata) the last year, it was scary experience without counterholding it.
Thanks.
