Old 01-06-2017, 12:18 PM   #8
Lapister
I'm assuming you took off the TB and you cleaned both sides of the butterfly valve? First time I performed the service it ran rough too. Found the TB connector slightly loose ( not making). The point I'm really trying to make here is some people clean just the outside area of the TB and when they go to start the car it runs even rougher cause all the gummy deposits are suspended on the inside of the butterfly valve and feathering the slightly open valve reducing a smooth flow of air.
Lapister is offline   Reply With Quote
