Good golly Miss Molly
It ain't Unicorn sperm and while it is more expensive them most other coolant, IIRC, it technically is permanent so one you change it, its there for the life of the engine or until you replace the water pump, coolant tank, hose , etc....
I did my water pump, low temp thermostat and coolant and it was under $350. Add labor if you don't DIY
2004 996 Targa Tip
Instructor - San Diego region
