3.2 Used brake rotors
Doing more DE events so I upgraded my rotors to Sebros slotted rotors when my pads were worn out. These rotors were the original OEM cross drilled rotors.
Here are the minimum thicknesses I measured for each rotor:
Fronts: 1.050 and 1.045 in
Rears: 0.900 and 0.898 in
The min thickness specs are 1.023 and 0.866, so these could be machined or just used as is if you need a low cost solution. They were not warped an no corrosion (Arizona).
$70 front pair
$50 rear pair
Shipping extra
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
