Old 01-03-2017, 02:05 AM   #307
particlewave
Originally Posted by fridsten View Post
I'm considering opening up my muffler, enlarging the holes where the pipes enter, thus making what could pretty much be called an internal Pedro mod.
Drilling by the red arrows would allow the exhausts to follow the blue arrows into the outlet.
Would that work? It would be a fairly easy mod to make, provided you're able to weld or get someone to do it for you. It would also look completely stock from the outside.
I'm going to go right through the top of the muffler and into the inlet pipe with one or two 1" holes.
Internal muffler bypass that does the same as bypass pipes or the Porsche Sport Exhaust.
1" hole drilled in shell and pilot hole drilled into inlet pipe.
Inlet pipe hole widened to 7/8"
I punched through both the top and bottom of the inlet pipes and widened each to 1", so two 1" holes in each.
The cross sectional area of a 1.5" bypass pipe is 1.77".
The cross sectional area of a 1" hole is 0.79", so I have a total of 1.58" per side...very close to the 1.5" bypass pipe.
I'm going to get the shell holes closed up tomorrow and muffler reinstalled, then I'll test it out on Wednesday, so I'll report back then with results.
