Old 01-02-2017, 04:55 PM   #25
BoomerRoadie
husker boxster,
I'm not sure if I totally follow you. It sounds like you are saying that 15" jack stands will require longer amounts of time and extra steps, whereas the 10" 2-ton jack stands will not.
Presumably this is a function of the garage lift and the range it offers. I'm not sure I understand why it will take longer to jack the car up to a 15" height. I mean I get it, it's 5 inches higher, but does that require additional step?
The jack I am going to buy tomorrow is the Daytona one from HF. That has a range from around 3" to a little over 20". Can you not just jack the car up to the 15" minimum height of the 6-ton jack stand?
BoomerRoadie is offline   Reply With Quote
