Old 01-02-2017, 09:57 AM   #1
particlewave
Taking a resistance reading on a sensor like this will tell you exactly squat.
Remove the fuel pump relay (so the engine won't start) and turn the key. Does the tach needle bounce when you crank the engine? If it does, the CPS is fine. If the needle doesn't move at all, it's likely bad.
