Old 01-02-2017, 07:34 AM   #5
Anker
Bummer, I was looking at cam shaft position sensor, but you were asking for crank shaft position sensor.
The crank shaft position sensor is also a pulse sending unit and works off the flywheel. Everything I said about the camshaft position sensor also applies here. The sensor itself is mounted on the crank case.
1941 Dodge Luxury Liner Coupe
