Old 01-02-2017, 06:06 AM   #4
bonesy
Hi did mine to fit double din Pioneer SPH-DA 120.
Easy to do, hardest thing is getting the plugs through for the HVAC unit in the lower position. But stick with it and you will get there!
Don't be fooled into buying the trim to move the HVAC unit off fleabay...they wanted £29.99 here in the uk. I got the exact same trim from Porsche for £4.60!
I have left the cup holders in as well (personal choice) lots of "kits" you can buy is only if you remove the holders. I used the old trim to fill the gap under the head unit by cutting it to suit. I have ordered a double usb lead that i plan to fit into the space on the opposite side to the cigarette lighter but am still waiting on it. Hope this helps
also added splash screen
bonesy is offline   Reply With Quote
