Old 01-01-2017, 02:11 PM   #11
ttomtom
You should not be using a steel or stainless steel drain plug on these cars. Porsche purposely use an aluminum plug that is softer than the sump cover to reduce the possibilities of the plug tearing up the sump cover. Next oil change, go back to an aluminum unit.
Yeah I figured.
Thank you guys.
ttomtom is offline   Reply With Quote
