Old 12-31-2016, 05:23 AM   #16
Flavor 987S
Originally Posted by gomarlins3 View Post
I stripped out the plug this morning while trying to change the oil. Now I am trying to figure out how I can get the plug out. Any ideas? I don't want to drop the entire pan if I can avoid it.
Always remember, these magnetic drain plugs require FAR LESS torque when re-installing. I use the L&N Magnetic Billet Drain Plug and the torque spec is only a low 19 ft.lbs. This may have been part of your problem.
Not sure what part your stripped, so maybe you can tap a larger allen or hex wrench into the plug and remove? Sorry. Good luck.
