Old 12-30-2016, 04:52 PM   #11
mmassey0125
You want to get as much of the old oil out that you can, and to do so you need the cat to be level. What I do is to use one floor jack to raise the whole rear end up and slip 2 jackstands under the rear. Take the plug out and filter off then remove the jackstands and lower the car over the oil catch pan.
Sent from my SAMSUNG-SM-N920A using Tapatalk
mmassey0125 is offline   Reply With Quote
