Old 12-29-2016, 09:00 AM   #20
ryanjboutin
POG champ, 1995.
Still waiting on the new motor mount to arrive, and some other pieces and parts.
Supposed to arrive by close of business today, we'll see.
In the mean time, did the smoker's delete.
Took all of about 7 minutes.
Link to smoker delete: https://www.ecstuning.com/b-genuine...ers-shelf-console-kit-black/99655209601a03kt/
Yes, it's pricey. I understand.
I would not have done this if the lid on my ashtray would stay shut.
Directions:
Open ash tray, pull it out straight up by the lid after removing the two torx screws.
Pull out the switch surround.
Get a small screw driver and pry the outside guides (just a little bit) as you push on the face of the buttons.
They should pop right out without incident. You should also unclip the light bulb connector.
Install the switches in your new switch surround. White connectors to left side, black connectors to right side.
Function test the 4 switches.
Place the switch panel in the car, line up the new smoker delete trim piece, install new torx screws.
1999 Boxster 2.5l 5-spd. 168k miles and climbing.
Build: http://986forum.com/forums/show-tell-gallery/63257-greta-not-really-build-so-much-maintenance-record-build-thread-w-bs.html
IG: @ryanjboutin
ryanjboutin is offline   Reply With Quote
