Changing the motor mount is a reasonable easy DIY.
You can buy just the insert for around $40 rather than the entire assembly for around $150 (IIRC)
If you do the insert, you will need a press to remove the old insert and and press in the new one
As a while your in there...
Replace the water pump and thermostat. It also makes it easier to do the motor mount as you have the hoses disconnected
2004 996 Targa Tip
Instructor - San Diego region
