Ok success!
24mm deep six sided socket (this was sacrificial for me) with BFH.
Pull wheel off, start at front of liner and remove screws, pops, nuts and torx fasterners.
find cable on other side of headlight (use small screw driver to create a T handle and not cut fingers), pull pretty hard.
Open hood, disconnect battery wait 20 mins for good measure (re-route cable to tow hook thru removed passenger light while waiting), re-attach battery and presto; remote works again,
I didn't change anything in the handle (just the black electric latch attached to the edge of the door with 2 triple square bolts) and I did re-attach the little stud with the snap over collar. Maybe I didn't get the paddle in the receptacle? I'll have to look at that next.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
