I also got a new Durametric cable and scanned my 2003 Base. Everything looked good. There were a few "yellow" warning codes, likely the result of battery disconnect I did when taking the seats out for repair) that I could clear.
I could not clear "red" codes 9114 (Instrument Cluster K21 - PCM control unit) and 38 (Automatic A/C H01 - PCM CAN timeout fault).
The car has its original CDR23 head unit that I had to send away to Becker for testing (it was fine, the amp was not and was replaced with a reconditioned unit). The head unit does mysteriously power down by itself sometimes, but otherwise works fine.
The only thing I can think of related to the A/C is I fixed the common "blowing foam' problem and had the mixing flap out of the car to re-foam/tape.
The car runs like a top otherwise, and I'm not too concerned about these codes - but the OCD in me makes me want them to be resolved or cleared. Any ideas?
