Take the package shelf that contains the speakers out. With the top in the service position, there are two quarter turn plastic screws in the top of the shelf. Loosen the screws and then disconnect the speakers wire harness from the passenger side of the car (follow wires and you'll find the connector).
Once the connector is disconnected, remove the entire shelf assembly and turn it over. remove the speaker grills and you're home free. The speakers are easy to remove and replace.
