I did exactly that. I powder coated a set of 17" Boxster twist wheel ( 7in F and 8.5 in R), and put Hankook R-S3 tires, 225/45s F and 255/40s R. I ran one complete DE on them. The R-S3s aren't the grippiest DOT tires, certainly not in the rain, but they are the value/price ratio is pretty good. They also talk to you very well and don't get too slick when hot. I figure even if I go through one set of them every year, that's not bad.
The 225s are already a little wider than I would want for the front 7in, but the 255s are fine for the Rear 8.5s.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
