Old 12-23-2016, 10:50 AM   #11
edc
550 Anniversary
edc's Avatar
The throttle body area part itself look very similar to a regular 986. What you do have is a more solid plastic MAF to TB pipe with a smoother curve. From memory the neck of then plenum is the same length as the regular one too. The MAF is also further ER away from the airbox almost next to the TB.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
