Old 12-21-2016, 05:44 PM   #2
nicecar
I had the same problem and if I remember correctly the fastne that holds the h.l.. frame to the body is a unique piece.I did alot of searches on the subject and did have to order 1 of 3. Look at a parts diagram and you will see that once you see how they work it is pretty simple just as german engineering goes. I hope this helps.....I am by no means a mechanic. I think I held the bottom of the the thumb screw with a torx to tighten.It always helps to take a step back and go back in fresh after a while IMO
nicecar is offline   Reply With Quote
