Old 12-21-2016, 11:14 AM   #1
djw8282
djw8282's Avatar
i used the torx screws. pull off the clips on the mounting tabs and replace with smaller ones (the smaller, universal, body clips worked for me). i thought about retrofitting the 986 system to the 987 cover, but the 986 cover is much thicker and i would have had to fabricate spacers.
fyi, you do this to reduce weight and increase space in the engine compartment for intake mods, engine swaps, etc.
Exactly.. Its to increase space. I did the the 997 plenum and TB modification and I like a little more space. Another reason is the 986 engine cover is plastic with an aluminum heat shield. It tends to rattle over time. I like the fact the 987 cover is one solid aluminum piece. I'm sure it will reduce the rattle and secure nice and solid. Weight savings is always a plus!
Thanks for the info Radium King! .. Just what I'm looking for.. Any chance you can direct me to these universal body clips (link) ? Where did you get them? Thanks!
djw8282 is offline   Reply With Quote
