Old 12-19-2016, 06:20 AM   #10
Aviator912
Thanks chaps,
I think I'll look more closely at the foam trays, it sounds to me like that will be the most likely cause, but I can't see when they would have been damaged. The problem wasn't there over the Summer and I haven't had the hood down while the problem occurred. I checked the carpet at higher level near the doors and it is dry, so I don't think its tracking down inside the door.
The back section of carpet is also dry. All the electrics are bone dry under the seat, the water only looks as though settles behind the seat.
Somebody mentioned that it is possible to dislodge a tube inside the drain, how do you check this?
Tks
Aviator912 is offline   Reply With Quote
