Old 12-18-2016, 01:21 PM   #12
JFP in PA
Originally Posted by Tweedboru View Post
Hi , I found the quickest and easiest method was to undo the metal jubilee type clamp on the rubber CV boot. slide the boot back a little way, then you have direct access to the bolts. they are very tight and may need a rattler to undo. Added bonus check CV for grease.
Brian
Unnecessary. Use long Allan keys and rotate the axle to expose the bolts. Should not take more than 5 min. per side to disassemble.
