Old 12-18-2016, 01:05 PM   #11
Tweedboru
Removing cv bolts
Hi , I found the quickest and easiest method was to undo the metal jubilee type clamp on the rubber CV boot. slide the boot back a little way, then you have direct access to the bolts. they are very tight and may need a rattler to undo. Added bonus check CV for grease.
Brian
Tweedboru is offline   Reply With Quote
