Originally Posted by Smallblock454
Why not drilling a small hole along the groove of the allen drive? All metal debree can be removed. The IMS tube is full accessible, so you remove debree. Oil pump is also full accessible. The hole must not be that big.
The downside of the idea in general: you loose oil pressure for other engine components.
Regards, Markus
How are these roller bearing installations handling thrust loads ...if there are any. Do any have this installed? I hope oil film is not being relied upon.
Personally, I would not be at all on board with putting a groove down the length of my oil pump hex drive. A centre hole may work if you are a gambling man. That section looks too small to begin with an now one has introduced notch sensitivity that is off the scale for torsion.....imho
